| Stucco
over cedar siding:
I live in a cedar home
in a rural
area with many trees. Over the years woodpeckers have done a job
on some of the walls and I have been
thinking of replacing several of the
walls
with stucco. I noticed several homes in nearby neighborhoods that
have been "stuccoed" right over
the existing wood siding. The
owners
are content but I am uncomfortable with this. Should I be?
I have had quite a few readers write
about putting
stucco on their
house with siding. Over wood siding such as
cedar
or T-111 the
metal lath can be put right on the wood
without
any problem.
The wood can provide addition support for
wall like sheathing.
The qustion is here, do you have
adequate space
around your windows?
Adding 3/4" of material can bury your
windows,
and worse, the sills,
allowing water infiltration. If not, tear
off
the siding. Also, if your
cedar or T-111 shows extensive rot, it
isn't
a bad idea to tear it off.
Vinyl or aluminum siding should always
be torn
off. It is impossible
do have a good nailing surface otherwise.
Siding
can be torn off easily.
The trick is to start from the top.
